Directv (R10) DTV Receiver / 70-Hours Video Recorder Logo
A
Anonymous Posted on Apr 13, 2013
Direct tv hr23-700 power supply - Directv (R10) DTV Receiver / 70-Hours Video Recorder
The main power supply failure when switch on the TV
Pl. check main fuse of your house any loose contact may fail your mains power supply,as there is heavy current drawn as you switch on TV set for few seconds.If the mains fuse is o.k than there may be direct shorting inside the TV set,call expert technician to rectify the same.
I am on Direct TV. That part works fine. The tv however takes several minutes for display to come on.
The tv power supply board is the problems and the causes.U have all the tools and understand basic electronic also can do basic soldering?The power supply board,that the board,where the power a/c cord plug into it.Searches the power supply board for dying and soon to be dead parts call capacitors.These dying capacitors parts are alway bulges or puffing up on it tops.By replacing all these dying capacitors,ur tv will power up right away and have picture quickly,no more taking up times,like several minutes to power up and have picture.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
1helpful
Powering tv
Read any information on the 240v to 12v adaptor. If the 12v is DC yes you can use the Battery direct. If it is 12ac no can do.
Mike
3helpful
Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
2answers
High pitched noise
The power supply is starting to fail on your LCD. The noise you hear is because the circuit is trying to provide the proper power to the rest of the circuitry and is forcing itself.
The noise does increase if you tune to an HD channel because of more demand for power for a brighter picture.
Let me know if you need further assistance.
Our newly purchased Toshiba - REGZA 42" 1080p Flat-Panel LCD HDTV has a fuzzy "snowy" picture. Direct TV is our satelite provider.
First check if this happens in other external video source as well, like DVD/CD/VCR, etc. If it does, get the set replaced under warranty.
If it happens only with the Direct TV setup, try unplugging the set top box from both power supply and TV. Wait about a minute and reconnect. If the problem is rectified, the issue is with the setop box. Call Direct TV in this case.
1helpful
3answers
Tv shuts off
My TV turns on and off constantly, it wont stay on for more than 2 secs. Please help.
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
