Question about Sony Handycam HDR-HC1E HDV Digital Camcorder
My Sony HDR-HC1 NTSC will not power on.
In the midst of recording, the power shut off and the LCD screen and the view finder went black. The only response that I get when I try to power on is a white flash of light every 5 seconds. I have tried it with a fully charged battery and with the electrical cord plugged into the machine.
    New Friend:
  • 37 Answers
What if there's no tape inside of the camera, does it still same?
Posted on Feb 09, 2018
SOURCE:
SOURCE: HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Posted on Dec 29, 2007
  • 1894 Answers
SOURCE: My Sony HDR HC1 will not power on.
this is some problem with the internal software or hardware. nohting to do with externals. check it out by doing a hard reset.
Posted on Mar 09, 2009
  • 30 Answers
SOURCE: HDR-HC1 video camera won't close after you put the tape in. Hmm
MECHANIZAM fauly.repalace it by expert.
Posted on Jun 21, 2009
welcomejee
  • 10594 Answers
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
SOURCE: HDR-HC1 LCD screen is only illuminated when
http://www.eserviceinfo.com/download.php?fileid=42561
You will need to download all 6 parts and then extract the files.
Posted on May 31, 2010
HDR-HC1 flashes when recording outside only but not when recording inside. the LCD screen blinks light & dark. thanks john
This is a fault in the electronic aperture control and will probably cost you $800 if you have it repaired by Sony. However, There are many qualified independent repair shops that will do the repair at a discounted price.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 04, 2011 | Sony HDR-HC1 Mini DV Digital Camcorder
View Finder Problem on Sony HDR FX1E
Hello Sir,
Well this sound like the shutter may be trapped, either by a knock or heat on the system, maybe you could take it to camera shop and let them see.
May 27, 2010 | Sony HDR-FX1000 Mini DV Camcorder
The lcd screen is lit up but none of the touch screen works so i can't access the menu, yet i can still record, but on playback i can't press play rewind etc
touch screen deactivated? checked manual?
to activate you have to put her in play back mode by moving that switch
so please read some basic instruction or let somebody demo it to you :-)
May 26, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
CAMERA DOT CAPTURE TO LAP TOP
Make sure your camera is set to Play/Edit mode.
May 06, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Mar 09, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Sony Handycam HDR-HC1E HDV Digital Camcorder Logo
77 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
