My computer does not recognize my USB.It says 'One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it'.When i went to the device manager it read Unknown Device and when i checked the properties the Device status reads 'No drivers are installed for this device'.The driver version is 5.1.2600.0.The driver provider is Microsoft and the driver date is 7/1/2001 and also the digital signer is Microsoft Windows Publisher.Can someone solve this problem for me cos my memory card is working alright but my computer just cant recognize my usb
I am sending a couple of articles to help you with troubleshooting this issue, hope this helps. USB Memory Stick not recognized by Windows 10
What to Try When Your USB Device is an Unknown Device
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
SOURCE: usb cruzer micro and other usb storage devices malfunction...
in windows xp i am unable to format my scandisk 1gb cruzer
SOURCE: SanDisk 2GB Cruzer Micro USB device driver for Windows 98
you are not going to find that, since those sandisks came AFTER W98 had gone unsupported..
usb issues are under control panel, system device manager..check for conflicts or blown drivers
SOURCE: REG - windows not recognised
For some models pressing select and the + volume button for 10 sec resets the device and it is recognized by the pc on connecting. Check ur manual to check the way to reset ur device. You can download the manual from http://www.sandisk.com in case you have misplaced it. Drop me a mail at [email protected] to let me know if the solution worked for you.
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
SOURCE: Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
