Motorola MC9190-GST Logo
A
Anonymous Posted on Apr 12, 2013
Mc9190 laser beam width is too wide. I need to change the width of the beam. How can I do this?
  • Official Brand Answer 1,623 Answers
  • Posted on Jan 31, 2015
Fixya Pro
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350206
Points
5677
Hello
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Just purchased the Arlec AT4003 rechargeable Lithium torch from Bunnings today. How do I narrow the beam width. The packaging says it narrows from wide to narrow
Can you twist the bezel or cylinder? That is the way to change the focal length - I'm assuming you mean the AT0003 head light torch?
1helpful
How do I change the stitch width when using applique patterns?
The stitch width should adjust up to at least 1/4" wide. When doing applique, set the machine so the needle is centered on the raw edge of the fabric. If your machine is not stitching wide enough to cover the raw edge, then perhaps something is amiss with the machine. May need to take it for service.
How do I narrow the scan beam on the n410
The scan beam is fixed and can not be adjusted. However moving the n410 closer to the bar code will reduce the width of the beam itself. The narrow beam is designed to accommodate static stands as well as manual use.
Simply hold the n410 a few inches away from the bar code and the beam will be able to read the code underneath. No adjustment except the distance between the n410 and the barcode is required.
2answers
Mc9100 does not have laser
Contact Motorola Solutions. http://www.motorolasolutions.com/contactus
2answers
Motorola MC9190-G beam width setting
Hi
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads
Mark
3helpful
2answers
MC9190 WLAN Problem
To permanently disable the Suspend Mode on a MC9190:
On your PC, create an empty text file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout" = dword:00000000
Save the file, then change the extension to ".reg". This changes the text file into a registry file.
Copy the registry file in the /Application folder of the scanner gun. Cold boot the device. Your MC9190 will no longer go to sleep mode, or "suspend mode".
To automatically enable the Wireless antenna at startup, create another registry file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\WLAN]
"InitialState"=dword:00000000
Save the file, and copy it into the /Application folder of the scanner gun. Cold boot the device.
1helpful
I have a mfc-8440, 5 years old, low usage, 50% drum life, new toner cartridge. The problem is that the contrast of the printed copy does not change regardless of the setting using the path...
This is very easy to solve. Remove the drum and toner cartridge. Look into the machine where they sat. Now look up and you will see (a little aukward but its there) a glass plate the width of an A4 sheet of paper. Run your finger accross it. Look at your finger and will probably be dirty. This is the window the laser beam passes thru to hit the drum. When its dirty it does not allow enough ;light to the drum hence a weak beam and light printing.
simples?
Which width should I choose when I place an order for NB shoes?
Width is the measurement across the widest part of your forefoot.This measurement runs in correlation to the length of your foot, and can best be found by having you foot properly measured. The average men's width, typically referred to as medium, is a men's D width. For women, the average, or medium, is a B. Listed below is a chart that helps indicate the width markings and their meanings.
Women's Widths .
4A -Extra
2A-Narrow
B- Medium
D-Wide
2E-Extra Wide 4E-Extra Extra Wide. Men's Widths - 2A -Extra Narrow. B-Narrow. D- Medium.2E-Wide. 4E -Extra Wide.6E- Extra Extra Wide.
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
