Question about Husqvarna Garden
How to adjust carb screws on husqvarna 125b blower
  • Husqvarna Master
  • 1,807 Answers
You need a special carb screw tool for Walbro carbs. Readily available from eBay, search ''Carb Adjusting Tool for Partner/Husqvarna''
Posted on Apr 13, 2013
  • Jesse Coleman
    Jesse Coleman Oct 22, 2018
    Do not pull a carb rebuild until you have adjustments made to your high & low screws. If the engine is past its break in period it most likley needs the carb adjusted. Very simple....providing your lines and primer are clear and in good service.
  • Jesse Coleman
    Call if you need help
    New Friend:
Brand spanking new. Starts but bugs out when i step on the trigger.
They did not give me the key, sombitch !
Posted on May 02, 2015
SOURCE:
daneinwv
  • 124 Answers
SOURCE: husky 125B blower, new right
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Posted on Dec 09, 2010
SOURCE: I have a Husqvarna 125B leaf blower with less than
run for 10-20sec. cut off
Posted on Nov 06, 2010
  • 211 Answers
SOURCE: Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
Posted on Dec 05, 2008
  • 430 Answers
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Posted on Nov 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
Gas 125b husqvarna leaf blower won't run on "run".
These machines are set up for the best emissions and not the best running, you need to acquire the special tool to adjust the carb correctly, once you have the tool ( you can get this off e bay ) turn the H screw out about 10 minutes on a clock face and try again.
Apr 19, 2018 | Husqvarna Garden
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
What are the screw adjustments for the carburetor for 125B Grass Leaf Blower?
These should be set by a certified dealer using a tachometer. It is against Federal law to tamper with the adjustment screws. You can also damage or destroy the unit if they are not set properly.
Jun 13, 2014 | Husqvarna Hand Held Blower 125 B Grass...
I need to know the starting point and how may turns to adjust the high/low speed carb screws. I have the tool. but no in fo.
Both screws start at 1 turn out....Adjust High speed till it 4strokes and 2 strokes usually 1/8 turn either way....then adjust idle so it revs staight up...should be same 1/8 turn either way from start...if it is more carby will need overhauling..
Oct 09, 2013 | Husqvarna 125B Blower
Husqvarna only runs at half choke
Ours does the same thing. On Amazon you can buy the carb. adjusting tool for about $17 and will solve your problem. It solved ours.
May 26, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Nov 22, 2009 | Husqvarna Garden
Garden Logo
22,519 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
