Frigidaire 25 Pint Energy Star Dehumidifier Logo
Posted on Apr 12, 2013
MY 25 QT FRIGIDAIRE DEHUMIDIFER HAS NEVER COLLECTED ANY WATER
Melanie Lewis
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 03, 2015
Melanie Lewis
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
226
Points
My LG is the same way. I bought it brand new and still I have NEVER gotten one drop of water in it. I am very upset!!!!!
How do I remove the cabinet from a frigidaire dehumidifer?
Hey friend, thank you for your post!
I understand that you would like to remove the cabinet within your Frigidaire dehumidifier. Typically, the cabinet is not accessible. If you need to access anything internally within your dehumidifier I would suggest seeking assistance from a professional. Best regards! -Matt
Bucket full showing
Hello Friend, thank you for allowing me to assist you!
Once the "BUCKET FULL" illuminate on your Frigidaire dehumidifier, soon after your appliance will shut down. Then you may remove the bucket by pressing the sides gently to unclip it and empty the collected water. After you reinstall the bucket, the float switch will reset. Hope this helps! - Z
The dehumidifier is running constantly but no water is being collected
Sounds like you're in a wintery environment. Most people operate a humidifier in those locations because the air is too dry. If that is your situation, I suggest you turn the dehumidifier off until Summer and save electricity. If will pull moisture out of the air in the summer.
Dehumidifier is running and the filter is clean but it hasn't collected water in a couple weeks. It is in the basement, which is very moist, so I know there IS water to collect!!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
0-
I have a new Dehumidifer, but it is not pulling any moisture from my basement. No water is accumulating in the catch bucket. This is the second Frigidaire that I've had this problem with. The first was...
heatman101
1helpful
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
1helpful
Not collecting water
Hi..my name is Keith..and your unit has lost is evaporation/cooling capabilities...and its usually do to a freon leak..or the compressor has went out...i would suggest you buying another dehumidifer..i wish i had better news..i hope this has helped and im not always 100% correct..write back with any questions and i will try to help
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
