Need to make a new install disk for hp laptop got windows 7 iso file from microsoft got image to burn can't get the drivers to burn on the disk for my hp pavilion dv6910us pavilion entertainment pc have 7 zip file manager actually worked better than all the others i tried got image to burn but no drivers. Another question do have windows 7 install from my toshiba satellite will that work
OLD DV6910. note book. (circa 2007 ) near end of HP support.!
MS stopped VISTA this spring.
no, toshiba is no good, as are all other PCs makers disks no good. your PC us USA HP computer, its not from Japan.
sorry. only MS disks or best of best HP disks work.
the ISO from MS, how'd you get that, and when.?
the current link at MS needs valid RETAIL COA code to download it.(oem codes not)
The MS disk do not have all drivers need, to make an HP pc run..
sure it will load, but many things CAN be dead.
is your F11 restore dead too? (its VISTA, if you dont know)
power on , F11, f11, f11, f11 , hammer it. see the HP restore?
here is your official HP support page.'
https://support.hp.com/us-en/product/HP-Pavilion-dv6900-Entertainment-Notebook-PC-series/3725196/model/3740554
see? that
and all were shipped with VISTA, and F11 key restores
VISTA , there is no W7 drivers. from HP , zero
"i got image to burn.?"
so then what?, did you install W7?
and see all those dead chips? in device manager
did you get Ethernet working first so W7 can PNP the drivers automatically, /??
Things that can fail are.
HP special drivers for like , hot keys, that MS does not have
all HP apps will be missing.
and all drivers for old vista chips not supported under w7
see?>
MS loads. here is the path (using ms, disk and not HP media kit)
why not get the HP kit from HP???????
if you make a PCI scanner boot disk (or stick)
http://www.pcdied.com/pci-101.html
you can find most drivers. (mine never fails)
using he scanner on any PC we see all chips
and with vista drivers failing on w7
we go to the makers site and get the W7 driver
as seen here, PCI sniffer3 , I uses this all the time.
for exactly this reason.
the HP media kit DVD set is for VISTA only.
sorry.
SOURCE: HP Pavilion dv9000 Entertainment PC
I have had to send my laptop to Hp for the same problem.
Go to this page and see if your unit qualifies for the " HP Limited Warranty Service Enhancement"
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: need all the available win xp drivers for HP Pavilion 6205us.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3366690
There u go M8!
All the drivers you need
Good luck
Nic
DONT forget to RATE me
SOURCE: from vista basic to windows 7... T_T
Windows 7 is still in beta testing is it not? This means that various things are not going to work with this until they are ready to start selling to the public. You can not expect a program in beta testing to work with all periphial devices.
SOURCE: I have a toshiba A215-S5837 Satellite. The DVD
1. Try System Restore to rollback ur settings.
2. If it don't helps, u can update the drivers through internet!
Testimonial: "All the suggestions were great. I was able to restore the communication between the cd/dvd drive and sd card reader."
Click OK and it will begin extracting all installation files to the
USB drive. The whole process will take some time(10-15 minutes), so have
patience.
Once the installation is complete, reboot your computer. Now while
your system is starting up press the appropriate button(usually F1, F2,
F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the
startup order to boot USB by default, usually you will have to press F6
to move the selected USB device on top. Once done, save changes and
restart the system.
3rd Method:( Try this if both above methods are not working)
Using Ultra ISO application.
1) Download the free UltraISO trial by clicking on this
2) Start UltraISO as administrator
3) "Burn" the iso image to the USB stick by following these steps
With UltraISO:
- Open the image of Vista/Win7 with UltraISO
- Under BOOTABLE tab choose WRITE DISK IMAGE
- Choose your USB stick under "Disk Drive"
- Choose a method (It's recommended to use USB-HDD+)
- Press Write
PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
