SOURCE: It has 12% life left for its laser and fuser
If your prints are still looking good you can hold the 3 and 9 buttons together and arrow to the one you want to reset and reset them to 100%.
SOURCE: brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
SOURCE: Need info on replacing Laser & Fuser for Brother MFC 8860 DN
i have the same problem there is a phone number in the maual wich is the Brother support center 18772768437, after a few unnecesary question they will give a phone number of a company near your area that do maintenances services to copy machines, they are the one who will replace those parts, well at least that is what i think i just called them they are getting the prices, good luck.
SOURCE: Brother HL-5170 fuser reset
should be a service selection in the user tools/ menu. reset life/consumables/replacement etc.
SOURCE: Service manual for a Brother HL-6050DN Laser Printer
You can get the Service Manual for your printer by clicking on the Link below.
http://www.smpcshop.com/HL-6050-HL-6050D-HL-6050DN-p-4010.html
The price of $9.95. Thanks
