A CD/DVD is stuck in the E: drive. I pressed eject on the monitor and by right clicking on the E: drive found on My Computer.
You will have to manually eject the disc. take a straightened paper clip and find a little hole near the slot where the disc goes in. Insert the paper clip and it should eject the disc. If there is no hole, you may need to access the disc drive by removing the back panel and/or disc drive faceplate.
SOURCE: Hp IQ780A has a2discs stuck in the dvd drive
Woah! You don't want to hear this but forcing a second disc into the drive has probably destroyed the drive read head. They are pretty tough and it might be able to survive but you will most certainly have to dismantle the drive to remove the DVD and not create any more damage. Kind of like scraping someone elses car in a parking lot. More damage is done when you try to back off of the other car than the initial hit. (not like that's ever happened to me :) )
SOURCE: HP IQ770 TouchSmart doesn't load up or stay on
Step 1: Disabling Automatically restart option to view error messages
1. You can prevent the computer from restarting by turning off the Automatically Restart option:
2. Click Start .
3. Right-click Computer , and click Properties
4. Click Advanced system settings .
5. Click the Advanced tab and select Settings in the Startup and Recovery section.
6. Remove the check mark next to Automatically restart under System Failure .
7. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
8. Restart the computer.
Check if it happens again
If it happens again do a hard drive scan(FULL)
Download the latest BIOS update from hp.com
Step 2: Reinstall Microsoft SATA disk driver solution
1. HP Vista computers that use the Microsoft SATA disk driver do not experience automatic restarts. If you updated your Windows XP computer to a Windows Vista capable computer using an HP upgrade solution, this Microsoft SATA disk driver is available to reinstall.
2. To reinstall the Microsoft SATA disk driver, follow the instructions below.
3. Click Start on the taskbar.
4. Click All Programs , PC Help & Support , and then select Recovery Manager to open the Recovery Manager window.
5. If prompted, click Continue .
6. Click Next to continue.
7. The next window asks if you want to perform a program recovery. Select No , and then click Next .
8. The next window asks if you want to perform a driver recovery. Select Yes , and then click Next .
9. Click Next again to continue.
10. Select Standard Dual Channel PCI IDE Controller from the list of drivers, and then click Next . The reinstallation process takes a few seconds.
11.Click Finish to restart your computer.
