Safe mode and other F8 boot options do not work either. I do not have any cd or floppy drives on this computer, only a few USB outlets. Can I make a boot disk from a flash drive? And if I get around the autochk file problem can I keep my personal files or will the computer be completely wiped out? Normally my Aspire One has a eRecovery option one can run at BIOS bootup by pressing ALT + F10. I've used this before and was able to keep all my personal files, but this time it is not working....Thank you everyone for your time and help I greatly appreciate it!
No pc model told at all just inches.
no OS told last guy on XP on earth?the virus magnet from H3LL.
well if the hdd is bad, all that you told is what happens.
no hdd this old works why mess with any old hdd, get a SSD in there
and learn to backup private data. or lose it you will
so what now? and answered here 1000 times
move then hdd to 2nd GOOD pc with spare SATA port and get your data that way, if possible at all?"and only trying wins..
or to USB sata docking bay a $15 tool)
the old OS image files for recoveyr die the day any hdd dies.
this is REALTY . best is learn to backup,
SOURCE: Blue screen on my laptop
go to bios with F2 button. and you will see harddisk mode. IDE/AHCI change their situation.
SOURCE: i have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
SOURCE: blue screen of death comes up then the netbook turns off
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: when trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
SOURCE: My Acer Aspire One 150 netbook freezes even after OS re-install
Try formating your harddrive and reloading the OS. If that doesn't work you might need a new harddrive.
