SOURCE: oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
SOURCE: oil leaking from mixer head
This is a fairly normal problem and as long as there isn't a lot of oil leaking it doesn't usually indicate a problem. this oil is cause by the normal function of the machine and only requires time to time cleaning. since there is a gear inside the planetary it does usually have oil on it as well. However if you are getting more than desired leakage of if it is alot it could be the inner seals. There are 4 located inside the unit. and if broken or worn may have to be replaced. I can give you part numbers if you can supply a proper model number.hope this helps
Thanks
SOURCE: I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Testimonial: "I know,ust can't find them. If you could explain to me how, I would appreciate it"
SOURCE: i have a t801 mixer with a bent planetary shaft.
Remove the whole planetary from the bottom... There should be a large nut on the main shaft...remove it ....whole assembly drops down...careful...don't drop it......At the top of the bent shaft you should see some center punches holding a thin nut in place.....drill them slightly so you can loosen the nut. There are some studs that hold the lower bushings in place...remove them with a straight blade that fits the screw snug. You can have a new shaft made out of stress proof steel shafting from a competent machine shop........MONSTROSPIZZA.COM
