Don't know what car or engine you're writing about, but I'd recommend replacing the entire engine with a good used engine. White smoke usually comes from coolant in the engine (bad head gasket or cracked block/head). Fuel additives will do nothing to correct this. Low/no compression may be a piston ring, may be a holed piston, may be broken valves. You're going to pay someone to tear down the engine and they're going to find a lot more wrong than a bad piston ring. Just get another engine.
SOURCE: White smoke from tailpipe, running poorly.
Sorry to say this, but white smoke is a sure tale of a blown head gasket. A new injector might cure the flooding problem, but the intake manifold gasket could be bad also.
