Cycle will run empty or with a couple pieces of clothes. With a reg load it will start for 5 minutes then stops and beeps one beep, silent for 3 sec interval and then 7 beeps. We have had to power off and try rinse and spin, a few pieces at a time.
The 7 beeps you are hearing should relate to a chart in your manual. This will help you narrow down the issue. Let me know what you find.
Testimonial: "We found the problem by trying to find out the answer to your question about the error code. We watched the light blinks 7 then a pause and then 1. The manual gave only an example but I replaced the example with the 7 and 1. And it was an F7E1. I Googled the code and it said motor drive fault. So decided to take a look at the motor. Took the back off and found the service manual in the washer with the codes. Also found a broken wire. Ordered a new wire harness and will o ly have to plug it in when it arrives. Thanks. "
I posted wrong the light flashes 7 times and then pause and then 1 time, or visa versa. The manual said that the error code is F7E1, but it does not give me the error just an example like F8E1 is a long fill. I looked on the internet but can't find the error codes for a Whirlpool washing machine model #WFW9050XW00. I did run the machine with no clothes and it runs fine. With clothes it will only turn in one direction. So it will turn clockwise, then sit for a minute and then run clockwise again. Empty it will rotate clockwise for 40 sec and then stop for 5 sec and then rotate counterclockwise. If i put a few clothes is, it will run fine. Repairman said that it should not matter if there are clothes or no clothes but it does.
Finally found the problem and the code. The papers were inside the washing machine, the error was the drive motor. We looked at the moter and one of the wires was broken. Ordered a new wire harness. Should be able to plug in when it gets here. Thanks for the help.
Good work, see it pays off to look into it your self.
SOURCE: washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: Kenmore Front Load Washer, 417.44082400, will not
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
SOURCE: Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
I think i am wrong about the beeps, it beeps three quick beeps, pause and continues three beeps. If we wash empty it will run fine
