Xact Communication XTR1 SIRIUS Radio Receiver Logo
Posted on Mar 08, 2009
Trying to connect Sirius Xact Radio
Need the online manual for the Sirius
Xact Radio.
Stevo_1
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 27, 2009
Stevo_1
Contributor
Level 1:
Answers
Questions
0
Helped
967
Points
15
Xact xtr1 turns on then off
Hi try replacing the phones battery and see what happens.
Thanks!
Metal prongs on the antenna wire that plugs into the back of my Sirius radio have broken off. Can they be replace?
There are a couple of different ways the antenna connection can break. Docks and antenna replacements are available, though the actual prong itself may be difficult to track down.
2helpful
3helpful
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Signal Fading In and out
Most of the Xact models use the standard Sirius antenna. Unfortunately Xact no longer supports satellite radios. You can get a replacement antenna from any Sirius dealer and see if that works. Sounds like the antenna wiring might be broken or shorted out.
Satellite radio
I have several 'ghettoblasters' that fit this unit if interested --- Frank
1helpful
3helpful
2answers
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
