My cashing machine was working very well, but now the decimal point is not there some reason if tried to write 1.00 is showing 100 it adding but the decimal point is gone and store login is gone as well the address and phone bussines too, what can I do ?
Doesn't let me use cents, the les a can do is 1 without cents
when i press clear it show just "0" not 0.00
it's nothing that i can do to program cents in my machine
it's not let me even use "."
i did clear all the information that is working 0.00 is back, thats the only way to got my decimal back
Yes, it is a setting that normally can only be performed by a full clear. Make sure the battery is in good condition. That is the usual cause.
General error that means you are trying to use it incorrectly. Press clear then make sure you press the correct sequence of buttons.
SOURCE: key op error
HI,
I've already given you the manual and also the pg. no. to refer for the sol.
Did you have a look?
Or else please give me a min. will need 5min. to type the entire thing.
Please don't forget to accept my premium sol.
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
SOURCE: Royal Alpha 601sc cash register won't program.
Hi. I don't have a manual for that model. If you can flick me an electronic version, I'll try to help.
SOURCE: I need to find a replacement cash drawer for a
Go to acedepot. They have them for 49.95
www.acedepot.com/redrforroal6.html
