SOURCE: casio wave ceptor WVA-105H
Casio is a great watch company
you can get online manuals anytime
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2734&submit.x=49&submit.y=8
SOURCE: I am trying to change
I have a similar model. The electronics sometimes needs to be reset after the battery is changes. Get a magnifying glass and look closely at the stainless frame around the battery. There is a small AC mark and a triangle which points toward a small gold contact down in an adjacent hole. This contact must be shorted momentarily to the + side of the battery to reset the display. You can bend a metal paper clip to make the connection. You may have to try several times before it resets. It should reset to 12:00 and start running.
SOURCE: Casio wva-210 bracelet adjustment
This watch has cotter pins. The end that comes out looks like a screw head but it is not. It is a split pin and the end with the split is the large end and needs to come out first. The arrows tell you which way to take the pins out. Use a small punch and push from the side that has no split. This should also be the same direction the arrows are pointing.
SOURCE: Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
SOURCE: manual for watch casio wva-105h
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Hello. Finaly i found it:http://uhrforum.de/attachments/205457d12... The one i missed was the one at the right. There's also a third yellow metal spring through the plastic protection in contact whit the screw of the antena at right. May be this will help somebody else.
i apologize! THIS ONE is the good placement of the third spring:http://uhrforum.de/attachments/205813d12...
