Lenovo Master
- Posted on Apr 12, 2013
Re: How to UEFI mode? Based on Computers
Use Device Manager's Firmware option and select Boot from EFI Internal Shell.
Use the EFI internal shell, as follows:
Start the EFI internal shell from the EFI boot menu and
select the drive with the Windows product DVD or Windows PE. The
following example assumes that the drive is Fs0:
Shell> Fs0:
Start the EFI boot application. For example, on an x64 system, run the following command:
fs0:> \EFI\BOOT\BOOTX64.EFI
For an Intel Itanium system, run the following command:
Fs0:\EFI\BOOT\BOOTIA64.EFI
After the application starts, you may be immediately prompted
to press a key to boot from the drive to continue. Press a key to
continue booting from the installation media.
After the installation is complete, you can check whether
Windows used the EFI boot environment by running DiskPart and verifying
that the drive is formatted using the GPT file structure and that the
ESP and MSR partitions are present.
Lenovo 3000 g400
