I NEED DRIVERS FOR WINDOWS 7 FOR MY SMART LABEL PRINTER 200
Smart label drivers (and every other driver related problem) can be easily found here: Driver Update
have a nice day
Dennis
SOURCE: How do I set the printing preference for my smart
I guess you want to make this printer your default printer.
These are the steps
1 Click start then Printer and Fax
2 Locate the Printer you want set as the default Printer
3 Right click the computer and choice Set as Default Printer
this will set the printer to the preference printer.
SOURCE: need a different cable - Smart Printer 220
http://www.usbgear.com/computer_cable_details.cfm?sku=CHEAP-SERIAL&cats=199&catid=482%2C1303%2C199%2C461%2C106%2C1009%2C601
SOURCE: IM TRYING TO INSTALL SMART LABEL PRINTER 100, I
hi there..
could be the autoplay feature is not enabled... on your computer..
so in this case... click on my computer.. you should find ur cd drive specified.. double click on it.. .and please look for the .exe file..
how ever if you load it.. please check the requirements..
hope this helps..
SOURCE: i need driver of smart
Hello there.
The drivers are here: http://www.siibusinessproducts.com/support/slpsoft.html
Although it says up to Windows Vista, you will see that it also says Windows 7 ready. Sometimes installing Windows Vista 64bit driver works on Windows 7.
You can also try Windows Update. Windows 7 Updates sometimes recoqnize your missing hardware and attempts to find drivers for them.
Thank you. Let me know questions.
Download SLP400 Driver from Seiko.com. It says in red that it also works for SLP200 on Win 7. You have to register then you get a direct link by e-mail. You have 24 hrs to download the driver. Just had the same problem and it works!
