Today you are in much luck because you will learn about the best solution to recover music from Samsung phone effectively, backed up with many reviews from different users worldwide.FoneDog Android Data Recovery is compatible with almost any Android device which specializes in retrieving your lost or deleted data. Remember that once you have deleted a file or folder off your phone, they are not gone yet unless you will overwrite them with new ones. So we strongly recommend that when you experience data loss or accidental deletion, avoid saving a new music or file on the device because when you do so, this will make it difficult to recover music or files or much worst, it can be permanently gone.FoneDog Android Data Recovery was developed by dedicated engineers to give its software a user-friendly interface so that everyone can use it even those without any technical experiences.
Did you save any new data to your phone? If not, it is possible to recover your mp3, you know the files are saved in the SD card of your phone,so recover android phone data means recover SD card data, you can learn more from here: http://www.any-data-recovery.com/topics/mobile-devices/android-recovery.html
SOURCE: not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
SOURCE: TRYING TO LOAD MP3 FILES ONTO WALKMAN.
I have posted a solution for this problem here.
It seems you are not the only one with this problem.
If you have questions about it, or encounter other problems, feel free to post a comment on this question.
SOURCE: synchronize to continue your music subscription
The "synchronize files to continue" is annoying, and you are likely to get it again. If the music files on your player came from Rhapsody, the short-term solution is to re-synch the files through Rhapsody itself. If your subscription to Rhapsody, Overdrive, etc. ever expires, you will also get this message. The only long-term way around this problem is to only load songs that are in mp3 format (Rhapsody has an Mp3-Only subscription, which is different from its regular subscription; Limewire is another choice - but it is prone to have viruses, and some ISPs will cut off your broadband if you use the service). If you wanted to erase all songs and start over from scratch, you could update the firmware on the player - it will have the side effect of erasing everything on the player.
-Tha Mp3 Doctor
SOURCE: music will not play from mp3
I had this problem. Plug your Slick Stick player into your computer, then go to MY Computer, right click and then click on Explore. In the left pane, you should see your audio device under a drive letter like J or E or another. Click on it and it should show "Audio Player". Click on that and you should get a blank screen if your MICIN.DIR is gone. If it is, just right click in a clear section of the page, go down to New and click on Folder. Name the folder MICIN.DIR. NOW, you are ready to add music to your player. Just copy and paste your mp3 songs into the same page where your MICIN.DIR is. DO NOT PUT THESE mp3s into the MICIN.DIR folder, but outside of it. The mp3s CANNOT be in a folder of anykind, they should just be loose where you can see them. The player looks for files, mp3 or wma, NOT folders. To check and see how much space you have on your player just right click on "Audio Player", not audio device. Audio player should be under audio device. When you right click and the drop down menu appears, then go all the way to the bottom and left click on "Properties" A pie chart will pop up showing you the amount of used space and free space. Now, on the Emerson mp3 Stick, which is like the Slick Stick, you have to put your songs INSIDE the MICIN.DIR instead of outside the folder. This is the only way they will play. I don't know why it is different. If this does not help, then write me at: [email protected]. We will figure it out. My name is Olen.
