Apple iPod touch 4th Generation MP3 Player Logo
Posted on Apr 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipod touch replace battery
Replace battery
iRefresh LTD.
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Feb 25, 2014
iRefresh LTD.
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
13383
Points
35
Please don't try this install unless you know how to solder! The solder pads can easily be ripped off while de-soldering original battery. If this happens your iPod is trash! Let a repair shop do it. iPod touch 4th gen New Battery Replacement
Brian Sullivan
Level 3:
  • Apple Master 27,725 Answers
  • Posted on Apr 10, 2013
Brian Sullivan
Apple Master
Level 3:
Answers
27725
Questions
Helped
5665869
Points
79191
You need to solder one in
Replace 4th Generation iPod Battery http://www.youtube.com/watch?v=v8-KUt8PVFY
iPod Touch 4th Gen Instructions http://www.youtube.com/watch?v=X1B5iu3ILkY How to replace your ipod touch 4th gen Battery
Ipod replace battery
which gen ?
iPod Touch Gen 3 Battery Replacement Directions http://www.youtube.com/watch?v=2lRuaoiaBhg
tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 • Apple iPod touch
tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
How to change battery in Ipod touch
You have not said what generation of ipod touch you have but look at http://www.ifixit.com/Device/iPod_Touch they have battery replacement guides for 1st, 2nd and 3rd generation guides for battery replacement and a teardown guide for the 4th generation. Hope this helps.
1helpful
Ipod touch
Your battery is draining too fast . There is some problem with the internal battery .Since it is brand new I will prefer you to go to apple service center to get your itouch repaired . Some products will be having these kind of problem . Apple will replace it .
Hope this helps .
Thanks for using Fixya.
tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 • Computers & Internet
tip
How do I set my iPod touch to tell me how long it will be Recharge?
<p>The iPod Touch, a portable media player from Apple, has an internal battery that will eventually run out of power while you reload. According to Apple, the iPod touch offers up to 40 hours of audio playback or up to seven hours of video playback when fully charged. The machine takes about two hours to recharge to 80 percent capacity, and about four hours to fully charge. Although the iPod Touch does not have an innate ability to tell you how long it will take to charge the battery today, you can create a free application that will give you an approximate time to load. <br /> <p>Preparation <br /> <p><br /> <p>1. Press the "Home" button below the touch screen of your iPod Touch. <br /> <p><br /> <p>2. Touch the "App Store" icon on the home screen. <br /> <p><br /> <p>3. Tap "Search" and enter a search term such as "Battery" and then "Search". Tap the name of an application results from the battery, such as "Battery Free HD", "Magic Battery" or "sense of battery Philips Consumer Lifestyle." Tap the word "free" next to the name of the application of the battery, and tap "Install. Tap your Apple ID at the prompt to download and install the application from the battery. <br /> <p><br /> <p>Battery Free HD <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "Battery Free HD" icon on the home screen app to start it. A battery icon appears with the current level, and details about the estimated time to play music, videos and surf the Internet. <br /> <p><br /> <p>3. Touch the screen with your finger and drag it upwards to scroll to the "Time to Charge" song to reveal. <br /> <p><br /> <p>Battery Magic <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "Magic Battery" icon on the home screen app to start it. A battery icon appears in a window below the current time available for various activities, such as "Play Game", "3D Game" and "Wi-Fi." <br /> <p><br /> <p>3. Touch the screen with your finger and drag to scroll the window until you see "loading time" with a number of how long it takes to load your iPod Touch. <br /> <p><br /> <p>Sense of the battery, Philips Consumer Lifestyle <br /> <p>1. Press the "Home" button of your iPod Touch. <br /> <p><br /> <p>2. Touch the "sense of the battery, Philips Consumer Lifestyle app icon on home screen to start it. The battery now appears as a percentage, with a grid above options for the different activities you can do with your iPod touch as" Audio playback "," Video Playback 'and' waiting time. " <br /> <p><br /> <p>3. Tap the "Time Charge" of the network. The amount of time it takes to fully charge your iPod Touch will show up under the grill. <br />
on Jul 21, 2011 • Computers & Internet
Haywire no its not jailbroken
It sounds to me like you itouch battery is getting ready to die. so it's not running your touch with the power needed. I would first replace your battery.
If replacing the battery doesn't help
you can restore your touch to factory settings in itunes.
go to itunes click restore and your touch will have new software.
remember restoring your touch, you will lose all apps, music,videos and pictures.
back up your device now while it is still in running condition.
Good Luck
If this helps you please leave a vote in fixya
1helpful
2answers
Battery run time
I used this ipod repair guide that shows how to replace the battery on an iPod touch using photos and instructions. The batteries wear out over time, expect about 1.5 years of usage if you recharge your iPod almost every day. Sometimes the batteries have manufacturing defects, in other cases the logic board has an error and drains the battery (ipod touch would get warm, if the latter was the case).
1helpful
4answers
Ipod touch will not charge
it looks like in all of these cases it's either a battery or a motherboard issue, both can be replaced by a tech savy user or friend if you use an iPod touch repair guide, the parts are readily availabe on ebay.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
