My dryer stops - Having looked inside the catch for the belt rollers had snapped so hubby has fixed this but now it still stops. without the belt on the spindle rotates freely and quietly but as soon as there's upward pressure from the belt it sounds as though something's catching inside the motor. Hubby used the shaft of his screwdriver to put downward pressure on the sprindle and this cured it so he thinks the spindle isn't aligned within the motor. He doesn't know how to fix that - Any ideas?
SOURCE: Hotpoint tumble drier TDL52S
you dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
SOURCE: tumble drier works but wont heat
Hi can you tell me what make model etc.... I then can tell you what is wrong!
SOURCE: fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
SOURCE: fixed new belt on hotpoint v3d00 tumble dryer now bangs on motor
the rear of the drun runs on a shaft part no 1703038 anythin from £10- £15.00 on ebay just type in hotpoint shaft kit
SOURCE: HELLO THERE TDL15P TUMBLE DRIER BUZZES WHEN
Seems to me that the motor brushes are shot ... Try espares.com if you are confident you can fix it yourself.
