Home Logo
Anonymous Posted on Apr 10, 2013
Where can I find a Sparta long reach pastry brush?
swetha
Level 2:
Habit-Forming:
New Friend:
  • Expert 73 Answers
  • Posted on Jan 20, 2016
swetha
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
73
Questions
Helped
19401
Points
453
Countryoven is providing diff types cakes flavors,Theme cakes,pastries, Barbie cakes.If you want to order pastries through online countryoven is the best they are providing excellent services.. Cakes
rosh edward
Level 2:
New Friend:
  • Expert 22 Answers
  • Posted on Sep 15, 2015
rosh edward
Expert
Level 2:
New Friend:
Answers
22
Questions
0
Helped
9086
Points
129
If you need to order pastry online Glendale Knows at Art's bakery Glendale is the best. If you need to order cake online Glendale call arts bakery.
Online Cake Delivery Glendale Order Cake Online Glendale
Anonymous
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Apr 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
52
Questions
44
Helped
27077
Points
56
Http://www.kitchenhaven.com/page/100/PROD/201300000/36520
Wet nuts inside grinding heads of WonderMill
1) Don't pour water into the chamber.
2) Grind some white rice through it. That should begin to absorb the almond oils. Dust it off with a pastry or paint brush.
The bit about the brushes comes straight from the manual:
https://www.thewondermill.com/pdfs/WonderMillManual_web.pdf
Just in case you have a clogging problem subsequently:
How to Unclogg Your WonderMill or Whisper Mill grain mill
tip
The Secret to Making Good Pastry
If you're not a massive baker, you probably get frightened at the thought of making your own pastry.
The ingredients of pastry are very basic. Flour, fat and water to bind it as a paste. But depending on the proportions of fat you use and how you incorporate it, will alter the kind of pastry you make.
If you are making short crust or puff pastry, you need to keep the pastry cool or it will be hard to work with. Handling pastry if it's very hot around or your hands are sweaty will not produce good results.
Pastry should be mixed quickly as it minimizes the gluten development. The more you work the pastry, the more the gluten gets activated and then pastry can become elastic and hard to roll.
The same applies to making pastry in the food processor - don't overwork it.
If you're making shortcrust pastry, put the dough in the fridge for 30 mins.
Here's a recipe for shortcrust pastry;
  • 7 oz plain flour or all purpose flour (see tip below)
  • Pinch of salt
  • 4 oz butter, cubed or an equal mix of butter and lard
  • 2-3 tbsp very cold water
Put the flour and butter in a clean bowl
Rub the butter into the flour using your fingertips until it resembles fine crumbs
Add the cold water to the mixture until it binds.
Wrap in cling film and put in the fridge for approx 30 mins.
on Jan 02, 2014 • Baking
What kind of carb cleaner should I use to clean my lawnmower carb
mower fuel in an ice cream container
(unleaded petrol )
a new pastry brush or paint brush
air compressor would be handy to blow the rubbish off before opening up the carby
and blowing the jets
Jan 13, 2017 • Garden
Granddaughter stuck wooden pastry brush in dishwasher in door opener. How do we get out.
She was just trying to help!!
  • Assuming it is the main door and not the detergent dispenser door,
  • Carefully remove screws securing washer under the counter. They will be above the main door screwed directly into the underside of the counter. I would expect only two.
  • Check to see if the machine is free. If so provide some protection under the feet as you pull as not to mare/scratch the floor. You can only lift it a little. If it is to tight than you may have to remove the kick plate and screw in the feet to allow for the unit to slide out from under the counter.
  • Slide the machine out about 4 inches. You should be able to see the door hinge and spring mechanics. There are drain hose fill hose and power wire attached to machine but they should have at least 4" of slack to allow for access.
  • Cut the pastry brush out. Reinstall washer. Locate previous screw holes in counter and install screws into the holes .Do not over tighten the screws into the counter. Do not let them go into the counter to far and mess up the top of the counter.
Thank the granddaughter for all her help and that Santa will be here soon!!!
Dec 04, 2015 • Dishwashers
Why can i not remove the kneading blade from admiral beadmaker
Pour very hot water into the pan and let it sit for 10 mins and see if you can wiggle it off. Pour out water first. Be careful as the pan and paddle will be hot. And anyway you can leave the paddle in, If you have a pastry brush brush a little vegetable oil on it, as this helps too.
3helpful
Sparta will not run
pixel and vertex shaders are video card features
check your computer specs (specially the video part)
Cleaning
Believe it or not but if it is a non-stick surface it can simply be brushed with cold water while the surface is still very hot. As long as you do this immediately after you remove the food. Try it with a pastry brush or similar.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
