Al kitchen and cooking stores sell kitchen scrapers, especially the silicone kind, and even most supermarkets sell them. If you would rather buying one online, however, here is a few links:
Silicone might not withstand heat. A better solution might be unscrewing handle from pot, replace waterproof washers and reinstall. That should stop the leak.
if it was poking out of the firewall from inside, it may be a drain hose from the ac ductwork inside the car which allows condensate water to drain when ac is on(you see asmall puddle of water under the car in summer when parked) its normal
It is most likely high-density silicone, which would be able to withstand the relatively high temperature and durable enough to withstand the repeated heating and cooling.
WARNING: You are taking a risk with your health using any non-food-grade material. They are not inspected for impurities and other trace contaminants that could make you very sick.
If your Jenn-Air model JES9750AAW oven door is squeaking, especially when heated, it could be caused by a variety of factors. Here are a few suggestions for fixing the problem:
Check the hinges: Make sure that the hinges are not bent or damaged, and that they are securely attached to the door and the oven. Tighten any loose screws, and make sure that the hinges are properly aligned.
Lubricate the hinges: If the hinges are not damaged, try lubricating them again, using a high-quality lubricant specifically designed for oven door hinges. Some examples are silicone lubricant, white lithium grease, or PTFE spray lubricant. These lubricants are heat-resistant and can withstand high temperatures.
Check the door gasket: The door gasket is the seal that runs around the edge of the door and helps to keep the heat inside the oven. Make sure that the gasket is not damaged or worn, and that it is securely attached to the door. A damaged gasket can cause the door to not seal properly and cause the squeaking noise.
Check the door handle: Make sure that the door handle is securely attached to the door. If it is loose, it can cause the door to not sit flush against the oven and cause the squeaking noise.
Call for service: If none of the above solutions work, it may be necessary to contact a professional technician to take a look at your oven and diagnose the problem.
High-temperature silicon glue will probably work ok. Be sure to clean the hole with alcohol and allow 24 hours for the glue to cure. Epoxy would be a better seal, but it doesn't adhere to plastic very well. Hope this helps!
SET OF 6 -- Meets or exceeds OE/OES specifications for fit, function,
performance, and quality; Features OE conductor construction and OE/OES
specified insulators, nipples, and terminals; Offers superior
fiberglass, silicone, and Kevlar construction for excellent
conductivity, high temperature, EMI/RFI noise suppression, durability,
and more; Meets SAE J2031 Class E specifications rated to withstand
temperatures from -40 to 428 degrees Fahrenheit; Designed with
click-in-place end caps that match to OE end caps for quick installation
and a tight fit without adjustment; Pre-cut for a perfect fit; Features
specially designed ignition cable and wiring systems to meet
customer-established performance, reliability, and cost; Passed strict
quality control and testing procedures to ensure consistent product
performance; Designed to protect electronic systems from electrical or
magnetic interference; Allows for all weather starting; Offers
resistance to heat, cold, and chemical attack; Carries a maximum
voltage; Won't crack or shrink.
Wet a hand towel or multiple layers of paper towel and lay it over the
sticky residue and turn the unit on high for 20 to 30 seconds to heat
it. Then use a plastic spatula to scrape it off. The heating should
loosen it up and the plastic spatula should be safe to scrape without
damaging it.
