I have an HP G60-535 laptop. I opened it to clean the cooling fan and change also the keyboard I used compressed air all over. When I put it back together the power button remains on and does not switch off, and also the screen is completely black and does not turn on. I appreciate any help. Thank you GP
SOURCE: HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
1) Turn off your laptop.
2) Remove Power supply.
3) Remove the battery and put it back again after 1 min.
4) Put power back and restart.
This should solve the porblem ! I have had it several times.
SOURCE: compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
SOURCE: HP Pavilion dv 9205 us tries to start up, screen stays black
THIS IS A LONG REPLY POST BE WARNED : HOWEVER IS LIKELY HELPFUL TO OTHERS WITH INTERMITTENT LCD / PORT ISSUES. MY STORY,... Hi all. Ok, i'm gonna chime in here on this. I have the HP DV9205us and i've returned my unit a total of three times. Ultimately I was told (under warranty for 24 ms) that it will likely need to be repaired due to same intermittent display and other intermittent issues with most ports. I had three different people 'working' on it. Uh-huh. They advised it would likely need to be replaced. I sent it in. Two weeks later I got my same laptop back. The billing sheet was $0.00 however, it stated they replaced the MB, HD, memory and LCD. The first repair was exactly what you're commenting on for intermittent ports and most notably display failure at times. I, again went through phone troubleshooting with them. Had to send it in a second time for same issue. They then told me they had to replace the MB and memory this second time. It worked for awhile. Within a few weeks (maybe five) the same issue happened. However, accompanying the intermittent issues was a serious heat problem. My unit was running VERY hot. In fact one of the ports actually melted the plastic side face. They asked me to send it back a third time and the billing sheet went down the list of everything replaced. MB, HD, memory, LCD and this time replaced the power supply. Hmmm,... I though to myself. My unit overheated to the point of smoking and melting. They've now replaced everything at least twice or more. Now they have basically given me a whole different laptop with piecing it together and now my case is melted. I contacted them and they advised that it was 'cosmetic' and not covered by my extended warranty. I wasn't pleased to say the least being that they pieced together my supposedly new laptop over the course of hit and miss at my expense of course (time without laptop). I told them I took the extended warranty for almost $300 extra dollars and was told it was covered for EVERYTHING except intentional damage. i even bought the high joules-rated power compressor, blank media, screen wipes, plate cooler, etc. It didn't matter, he didn't relent. I was keeping this laptop. He stood his ground. Whatever my case may be it's not going to be as agreed. So, I moved on to the second question. Why was my power supply replaced the third time and not the first time? He began to state it was customary to troubleshoot in a chain method until it's resolved. I then posed to him, why they sent me a differnt power supply this time. Different model than I was sold. He stated it was the same model. I told him I recorded everything for my insurance and it includes serial / model numbers. He read to me what the model of the PS should be and asked me if that's what I have. Of course i've got that one now. Why was I sold a defective PS in the first place. To me, it's very clear that my problems were resolved not by replacing everything in the pc. But by starting at the most common sense place. The power distribution from the wall pack or the MB. Nothing more. To me it was overkill to replace EVERYTHING multiple times. It told me HP didn't know what they were doing. It was a clear sign of that.
As of this date, I have had a functioning laptop without intermittent problems. No longer overheating and still am reminded by the scars on my melted case. Cosmetic? Umm,... I think that's why they spend millions marketing colors and flashy things. The look is what brings customers to see what the laptop offers. I actually researched HP and am a Sony guy typically. I bought my wife the Sony and I bought my HP. I waited two years to make the decision. I not only took the leap, I also took their full coverage option. I feel taking a laptop without the + warranty isn't smart investment. It depends on how mobile you'll be. Many people are business, as am I. Downtime is critical. Needless to say, I got no appology from HP. Meanwhile, my wife has yet to even reformat her HD again. With a year plus in my pocket, i've had to personally reimage four times trying to troubleshoot with them on the phone. Also, the two or three HD's they put in.
The long and short of it. HP took me for a ride. I sat patiently. I did everything they asked. I went without. I payed additional. In the end, I have a port module melted that reminds me every day that HP will not be welcomed anymore. I am sorry to kick them to the curb, but going off of how I was treated and the idiocracies they subjected me to in troubleshooting, i'd venture to guess many of you feel the same way. I'm sure mine is a little more labor intensive. I just want you to know your complaints didn't fall on deaf ears. HP abandoned the 9205 and I haven't found quite the same problems with the newer models. Aside from my treatment, I love the look and feel of HP. I have fourteen Sony products in my home entertainment system. Guess where my first look will be in the future of laptops? I shouldn't have strayed. My wife is plenty happy and i'm jealous.
Maybe the PS issue is related. Maybe ohm and test it for output. Most techie nerds you know can do this for you. Look for intermittent power delivery. HP never acknowledged the problem in writing. I couldn't even get them to acknowledge my question on the phone. It was the slippery-trickery on the phone. So, i'm passing it on. When I troubleshoot such problems in the future. I'll start at the most obvious. However, I have no problems with any Sony products nor my wife's (Sony) laptop. So, I don't figure on having it happen ever again. This is likely helpful to a variety of laptop owners with intermittent LCD / Port issues. Glad to help.
Thanks for allowing me to vent. I think I feel better. No wait,... may be the whiskey.
SOURCE: WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
SOURCE: laptop turns on but screen stays black
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a)
in power-on mode, open/unplug the data/vga cable of the monitor from
cabinet..see if raster or 'osd' is appearing on the monitor screen..if
so monitor is ok..else replace the monitor and see..[not applicable in
case of laptop]..
b) in case of laptop try to get output from
external display unit/monitor using vga port..if there's proper display
in there..the problem is probably with either the 'lcd' or 'ccfl' or
'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)
see if the ram(s) is loose/faulty..open clean/remove carbon &
or oxide formed on the teeth with an eraser n resit it..or replace with
a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust
neatly..dust is non-uniform in nature n may cause
jam/short circuitry/excess resistance n many more..resulting an increase
in heat..
7) open the CPU Heat-Sink with fan out of the
socket..put some "Heat Sink Compound" (available in local electronics
chip level spare market)between the cpu/processor and the CPU Heat Sink
*** fan..resit/fit it tightly in position..
8) on main/mother
board..see with a debug card for mb error..may b short..look for
defective capacitors(espabove1000mfd)/mosfets..go through the mb's
south bridge n the circuit lie around atx connector..the crystal clock
generator (if cpu isn't heating up)..
9) [in case of desktop] the
smps itself may b defective/faulty..check the outputs of smps viz. 0v
(black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg&
grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and
error amplifier ic',or pwm switching regulator circuit..look
for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
for
any further assistance u may plz leave comment and or testimonials at
any point of time, so that i/we can help or u think it to b helpful..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
