1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date 2. if off sync between analog and digital clock happen. You need to resyn step 1: follow the instruction 1 to set digital clock to 12:00. step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode. step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital. step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
I have the same clock and i went back to the shop to help me adjust the time today. I lost my manual and could not figure out how to adjust the time. First, push MODE until it displays the temperature. It will not work if the alarm time is being displayed. Then, hold MODE for a few seconds and the year, month, day will start to flash in sequence if you push MODE again. Push MODE again until the time starts to flash and there, you can adjust the time with + or -. Good Luck!
If I were you, I would go to the <a href="http://siliconewatchonline.com">silicone watch</a> manufacturer's website and check to see what they have there. If there isn't an instruction booklet online, simply call, email, or chat the customer service representative.
