97 chevy suburban k1500 brake lights work when pedal is barely touched then go off when pedal is pressed harder
SOURCE: 1994 CHEVY K1500 BRAKE LIGHTS DON'T WORK TOP CAB LIGHT WORKS
I figured out my problem!
From the VERY BEGINING... I changed my brake pedal switch with a BRAND NEW switch, and the lights still didn't work.
Well, I went back down there with a live wire and touched the contacts..and guess what.. the brake lights lit up!
I got a faulty NEW brake pedal switch!! I went a year with this problem, so learn from my issue, test even your new parts if it doesn't fix the problem to completely rule it out!
I hope you guys figure out what's going on with your issue.
SOURCE: rear brakes locking up with slight touch of brake pedal.
Most of the time with the rear brakes locking up the brake drums are warpped. If you remove the rear brake drums and take them to almost any auto parts store (Napa, Checkers ect.) they will turn the drums for about $10 a piece.
After you have the drums turned you will need to readjust the rear brakes.
SOURCE: no turn signals or side brake lights on 94 chevy suburban
or it could be the body control module is bad it is commonly known to go bad and all of the vehicles lighting is run through the body control module
SOURCE: 97 Chevy K1500 . daytime running lights work. Dash
ya im leaning the multi-function switch in the stearing column
SOURCE: 1994 chevy k1500
Have you checked or made your own earth source..Have you checked that you have power at the tail lights
