Got a few used phones, now all our lines wont let us use voicemail transfer. It says "denied in admin" none of our codes work to get the transfer button working again. HELP!
SOURCE: Nortel 1140E IP Phone, Expansion Module 1100 series not working
If you're running on a hosted PBX, the expansion module will not work. It only works on premis based systems.
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
SOURCE: my nortel voicemail is locked
You just need to have someone(system administrator) reset the password on your mailbox back to the default password. Good luck
SOURCE: checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
SOURCE: How do I remove Denied in Admin from a Nortel
You don't. Only the administrator who set that restriction can undo it.
