Trying to locate a Windows 7 USB driver for the Panasonic KX TA824
I am having below problem. When i receive call i can answer call from any extension without pressing any two digits. so let me know how to set security code. Like when i receive call i have to dial two digit first and than only i can answer.
-I want to block outgoing 411 calls.
- I only want customer can call local calls not long distance from there room
- How i can increase volume because when i join new system sound is getting low.
Hrgr
SOURCE: KX-TA824 Select idle CO line
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
SOURCE: We're trying to find the
It's not that super secret. If you register on the Panasonic web site, you can download it yourself. It's at www.btsdealer.com
IF YOU ARE NOT IN THE UNITED STATES IGNORE THE REST OF THIS!!!
I'm not sure, but I think you can go from v1 to v3 directly in a TA-824. Here's a link to my website for v3. http://www.public.carl.airpost.net/TA-824/ There are two pieces, the v3 tool and the v3 files. Download the file, save it somewhere you keep track of, then download the tool. Install and start the tool, the programmer code is INSTALLER, and click on HELP Help. Allow the ActiveX content and click on Program Utility, tab 8.1. These are the software upgrade instructions.
Just for safety, back up your data. In a nutshell, you run the upgrade, find the file, and the system will install the firmware, then convert your data. It's all automatic, but the end of the instructions will tell you what to do if something happens.
Let me know how it worked.
Carl
SOURCE: Cannot activate auto attendant on the Panasonic KX-TA824 phone system
For anyone looking for an answer, it is covered in more detail here
http://members4.boardhost.com/ablecomm/msg/1240472611.html
Carl
SOURCE: How do I forward calls to an outside number
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Testimonial: "Replies have been very useful and informative."
SOURCE: Installed a voice mail module card KX-TA82492 on a
O.K. I'll play. Did you program it to answer in 414-416? Did you record a message in BV 01? In the Features? manual 1.1.8 there are specific examples and instructions to make it work. It can be reached from the help files on the BV tab of the Maintenance console.
