We recently installed a duet II jacuzzi whirlpool bath. When we hook it up to power- the timer on the corner of the tub flashes 3 times and then that is it - it is the semi circle with the 7 or so little lights - we bought this item from someone who just took it out of their home- it was professionally installed and removed and they are at a loss as it worked fine for them - we cannot find a troubleshooting guide as to what this means - do we have to leave it plugged in for a certain amount of time before trying it - we do not want to finish enclosing it in without getting it running properly first... can anyone help the serial number for this is 0104264 - this is very frustrating and it is holding up the completion of our bathroom reno - we can not move forward until this is figured out any help is greatly appreciated!
SOURCE: Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
SOURCE: jacuzzi outdoor bath tub i have there is power but
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
SOURCE: My jacuzzi tub motor will hum but does not run. I
Turning the motor manually (with a wrench in my case (Jacuzzi Magnum Plus)) worked for me, now the pump is pumping happily away, thank you!
