SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
SOURCE: Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Testimonial: "Thanks for the speedy reply and your time."
SOURCE: Where does the water drain
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
