Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
A
Anonymous Posted on Apr 09, 2013
Kingston datatravler dtiu3/2gb want open in windows 7
1 Related Answer
Anonymous
  • 33 Answers
  • Posted on May 18, 2009
SOURCE: cannot download onto.4gbkingston datatravler
Hi norr951,
Here are some videos posted on Kingston's Website that will show you how to put your files onto your Data Traveler.
http://www.kingston.com/support/howtodt/default.asp
Kingston Tech Support
My Kingston flash drive 8gb doesnt get recognized by windows 7
Sometimes it comes with a software, you must have erased it.
Kingston datatraveler 410 can not log in
you might be better using a computer with xp to save your photos to another device or even burn them to a disk
windows 7 i have found if i use a data traveller on xp then try to use it on windows 7 it will always say it needs to be formatted do you want to format now
so i have designated certain data drives to my xp and others to my windows 7 although i have found that i can use small ones on each computer 1gb to 2GB
if you right click in the bottom toolbar when this is happening select task manager under applications you will see whats running if you dont want it to be running select end now also under processes see whats ticking over the same will apply
if you can get it to be recognised it might ask to be formatted
hope this helps
(how to use a datatraveler on corel paintshop ) is it possible to down load the pictures that are on my Corel paintshop on to a Kingston datatravler, if yes how can it be accessed. john
you will need to connect the device that has your corel paintshop to your computer once connected you might need to install it
click start all programs accessories open windows explorer navigate to your photos
right click on the photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photos to your usb drive then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device to see your usb drive click start click on my computer you should see your drives C: D: your drive might be E: or F:
if you are have trouble accessing your usb drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
hope this helps
1helpful
Kingston 2gb pendrive shows the drive but unable to open, format what to do
I have had this solution many times in the past, unfortunatly there is only one thing you can do...
This is assumeing you are running windows 7.
1. Open Command prompt by searching cmd in the start search aera. Right click on it and press "Run as administrator".
Type in the following - (Replace x with the drive letter that is indicated by windows.)
format x: /U
This will reformat the drive assumeing that there is no damage to the NOR chip and its command block.
4helpful
I want 2 run exfat pendrive in windows xp
First, your Windows XP must be either SP2 or SP3, and then you must add a patch to it. http://support.microsoft.com/kb/955704/en-us that is KB955794 for the patch
How to upload pictures by my usb
That really is a matter of if when plugged in to the USB port of the computer you are using, if computer you are using can recognize the drive.
If you are using Windows XP, check "My Computer" and you should see the Kingston USB jump drive showing as an device icon.
In Vista and Windows 7 select "Computer" and you should also see the USB jump drive listed as a device icon.
If you are using a Mac OS X computer with your Kingston jump drive, providing the drive has been formatted with the Mac OS Extended (Journaled) format, or the MS-DOS format (which is readable on both Mac and PC platforms), it will show up
in the Finder sidebar and on your Desktop.
Either platform however, to load pictures onto your Kingston is easy, all you have to do is either copy the pictures from there respective folder or location and either right click on the Kingston 2GB HD icon and paste the pictures.
Or you can double click on the Kingston 2GB USB icon and paste or drag the pictures into the open window of the Kingston 2GB USB jump drive.
That is honestly as simple as it is.
Now, on the other hand, here are a few steps, if you want to upload to an online resource which allows photo uploads from another source, namely your computer..
When you use the upload feature of that website or webpage to upload your pictures to, no matter whether you are on a Mac or PC, you simply have to click that uploader's Browse or Upload button.
Next, simply locate the Kingston 2GB USB jump drive in My Computer, (Windows XP), Computer (Vista , Win 7) or Devices and/or Desktop (Mac OS X).
Then start selecting and uploading your pictures onto that website or webpage with your Kingston as the source drive.
Yes, I have given you a number of options, but hopefully you will see the ease of using any of these methods, again depending on what computer operating system you are using, how easy it is to upload photos from your Kingston (DTIU3/2GB) 2 GB USB Hard Drive.
Regards,
-Mactechtrainer
Cannot download onto.4gbkingston datatravler
Hi norr951,
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
