Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
A
Anonymous Posted on Apr 08, 2013
FUF 14DTARWH freezer not freezing - Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
1helpful
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
1helpful
Fuf 14
If the compressor is running yet the suction (larger pipe) on the compressor is not cold, or if it is frozen, you probably have a refrigerant leak and need refrigerant.
Jun 11, 2014 • GE Freezers
Fuf 14dmdrwh
Is the motor running. Check if it has enough refrigerant gas. If the freezer runs normally for a long time and switches off, then replace the thermostat.
Jan 31, 2014 • GE Freezers
I want to know how long the warranty is for GE Model FUF 17DPHRWH, Serial Number DL177038. Thanks. My phone number is 806.335.3745
The warranty offered by GE on the FUF17DPHRWH is one year for parts and labor from the date of purchase if the unit fails due to a defect in materials or workmanship. If you pay for the GE Service Protection Plus, you will get longer coverage. (However, I've found that for most appliances, you would be better off putting the annual fee for the service in a savings account. Then when the appliance fails, use the money in the savings account to repair or replace the applaince.)
The manual is available here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60441.pdf . If this direct link doesn't work, start at http://www.geappliances.com/service_and_support/literature/ and enter the model number. Then click Submit.
I hope this helps.
(I have no way of looking up GE Service Protection plans.)
2answers
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Not freezing
check to see if your condenser is dirty, that can be the problem if looks clean, suspect low refrigerant charge
Freezer will not freeze except when using fast freeze
the electronic controller is faulty,make sure you have been supllied a freezer stat and not a refrigerator stat..
Nov 05, 2007 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
