Tryed priming with gas via spark plug engine will not fire
SOURCE: Have 2 craftsman riding mowers 42
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
SOURCE: engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
SOURCE: i have a cub cadet 1500 series and it wont start i
Check and see if it has an anti-backfire solenoid in the front of the carb.If it does and the solenoid has power then you need to replace it.
SOURCE: engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
SOURCE: I have a Craftsman Riding Mower DYS 4500. It has
You need to look at cleaning your carburetor out. It sounds as if the float may be stuck, or a metering hole plugged.
