Question about Karcher Garden
2600 PSI Pressure washer will not draw detergent up
Karcher 2600 PSI 2.3 gpm will not release the detergent when trying to clean
    New Friend:
  • 3 Answers
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Posted on Apr 19, 2013
5 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Posted on Apr 06, 2009
  • 306 Answers
SOURCE: no high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
Posted on May 04, 2009
SOURCE: pressure washer - can't figure out soap
Use your mouth to get the siphon started. That's what I did and mine worked great!
Posted on May 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
Need to know what type of oil is to be used in a pump assembly for a karcher G 2600 ph
Hello:
10W30 oil but make sure it is NON DETERGENT. Also be sure the reservoir is only 1/3 to 1/2 full
Jun 30, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
738 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
