RIM BlackBerry Curve 8520 Smartphone Logo
hermi8na Posted on Apr 09, 2013
I need to unlock my blackberry curve 8520 it doesnt want to go on the internet it tels me needs to conect wi-fi and i dont know how ive ask 2 degrees customer service for help they wont so can someone
Ok ive got a blackberry curve 8520 sell phone i need to unlock it or set up my wifi but i dont know how i asked 2degrees customer service for help and they have a problem with it.
Unlocking Expert
Level 1:
President:
  • Contributor 28 Answers
  • Posted on Jun 14, 2013
Unlocking Expert
Contributor
Level 1:
President:
Answers
28
Questions
0
Helped
10818
Points
80
Best place to unlock your BlackBerry 8520 with a IMEI unlocking code is @ http://bbcodes.co.uk/Unlock-BlackBerry-Curve-8520.php this site is the cheapest and fastest of them all!
  • RONALD CARTER JR May 31, 2014
    It sounds like your network has not been setup properly. You need to down load the blackberry desktop on to your pc and then plug it into your pc. First backup your phone on the desk top this way you can reload your information back onto the phone. It is a disk that they where giving away with the curve. If you don't have the disk you can go to any search engine and look for it. This will reset your phone back to factory settings. Next you can reload all your information back on to the phone. if you can not get this to work I can walk you through it.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Apr 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
2548
Points
27
Do you mean network unlock?
Testimonial: "im at contract at 2degrees and my phone ceep on asking conect wifi to go on the internet and it doesnt want to"
A
Anonymous
You can get the unlock code for your Blackberry Curve 8520 phone from UnBBLock.com and unlock your phone from Network lock easily.
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Nov 01, 2009
SOURCE: blackberry curve 8520 internet via gprs
You will have to be connected to EDGE or GPRS to use data services. If you are on edge or gprs (lower case), you will only have voice and sms.
Anonymous
  • Posted on Dec 07, 2010
SOURCE: when i try to go
you have likely dropped your phone and this has caused the lens to move.....open the back of your phone; remove the battery and gently press on the camera lens. Replace the battery and start your phone up again....see if this helps.
Anonymous
  • 541 Answers
  • Posted on Aug 10, 2009
SOURCE: i have a blackberry curve 8330 from sprint and i wanna unlock it?
you will get the unlock code only from the service provider from whome you have bought the handheld contact the them they would be able to give you more information that.
George Etukudo
  • 336 Answers
  • Posted on Aug 04, 2010
SOURCE: Blackberry Curve 8520 Signal problems
I don't think this is a phone problem.Bad signals is caused by network provider or probably you are in an area where signals is poor. But i don't think its a phone problem. Try leaving your area and go to another area and see if the problem still persists. Then you could see a Blackberry technician.
Best regards
Anonymous
  • Posted on Aug 29, 2011
SOURCE: is mixit posible on a blackberry 8520
Hey a can download my mxit but when a whant to open it says erre 11 I am celc pleas help
I cant use my internet connection wen i log in to facebook it says my cell is in data plan but i buy it in cash
Data plan means the Internet you use from the phone, maybe your facebook setting are to be use only on Wi-Fi. You need to carefully check your phone's settings.
3answers
Blackberry curve 8520 call failed
I think your Blackberry cell phone is locked to a specific network you need to unlock it,You can get unlock code at cheapest rate by BLACKBERRY CURVE 8520 UNLOCK CODE provider.
*Visit BLACKBERRY CURVE 8520 UNLOCK CODE
THANKS ! ! !
2answers
If you are asking Blackberry Curve 8520 Unlock Code you can get here,
THANKS ! ! !
9helpful
8answers
Unlock code for blackberry curve 8520
Hey, Call your service provider to ask your Blackberry Network Unlock Code. when you change your current network provider you must need to unlock your Blackberry first. after unlocking you can use your Blackberry to any network.but network provider take time to give your imei unlock code.second option is, you can buy your Blackberry 8520 Unlock Code from third party . this is safe way to Unlock your Blackberry . they will charge little amount but they give your Blackberry Imei unlock code immediately. i hope this information is help you. Good Luck:)
4helpful
8answers
How can i get the MEP CODE TO UNLOCK MY BB CURVE8520...CAN U HELP IT REALLY IMPORTANT.
Unlock your Blackberry CUVE 8520 eaisly with Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry Unlocking Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
2answers
Connected to wifi but cant browse internet on my blackberry 8520.
Solution:-
Disconnect from all connected network & then Reconnect to wi -fi.
Restart & configure your Wi-Fi- Router.
Thanks.
Happy to help you.
3helpful
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
