Televison & Video Logo
Posted on May 14, 2017
Top portion of the screen doesn't work. It's blank. 32" lcd Emerson
So I just purchased the tv used. I had a towel over the top when carrying it inside, but it may have gotten a little rain inside. It worked well when I first plugged my comp into the hdmi port. But shortly after started acting up. Screen not coming in etc.. Then froze on the startup screen. Buttons stopped working. I let it sit for an hour and turned it back on. It will now go to the normal screen and the buttons work, but the top 1/3rd of the screen is completely black. Any insight would be much appreciated.
Dario Hunski
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on May 14, 2017
Dario Hunski
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
995
Points
39
Look, if you had a towel on in you probably protected it well, in case you were carrying it for few meters from your car to house, but even if a few drops get it they are probably not gonna cause any massive problems if any at all + after you let it sit there for an hour it should work normally (if drops didn't burn any components, short curcuits etc...)
So my best guess is that you bought a broken TV. :/
5 Related Answers
Anonymous
  • Posted on Jul 26, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Anonymous
  • 1015 Answers
  • Posted on Sep 08, 2009
SOURCE: Monitor Blacks Out Randomly
Well If the monitor is brand new and you just purchased I would take it back and get another one as it appears to be defective. Most stores will allow you to exchange a defective item without a problem as long as you have the receipt. Any attemot to make repairs yourself could void the warranty. If it is used it may still be under warranty...I would get the model/serial number and contact Asus to have repairs made. Most monitors have at least a one year warranty.
Anonymous
  • Posted on Sep 26, 2009
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Anonymous
  • Posted on Dec 31, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Anonymous
  • Posted on Feb 17, 2010
SOURCE: TV is on but says it is still powering on
try unplugging the ethernet cable
How do you fix the loss of picture on a Emerson 32 flat screen
Hi Buddy,
There appears to be a problem in the Timing Control board. Please consult some local TV tech to do the job.
I have an Emerson 32" television when I power it on I only get sound but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Why is desktop green like theres way to much yellow hue
- Flickering screen
- Dim screen
- Slow start
How to change picture format for lc220em2 emerson
1. You need OEM remote (universals do not work). Link below to purchase.
2. Press the FORMAT button on the remote. SYLVANIA NH001UD Emerson LCD TV Remote Control
Hi i purchased a 32 in. lcd tv on black friday and know i went to turn it on and it flashed and know the red and green light stay on when u power it on
Disconnect the power completely. Wait 15 minutes. Plug back in. Turn on. If it doesn't clear, use your warranty.
8helpful
3answers
Can't get picture to fill entire screen on Emerson 32" LC320EM1
Hi
On the remote there's a button labeled "screen mode". Depending on what you're watching this will change the screen to what you like.
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
1helpful
Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
1helpful
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Top portion of screen blank
could be down to the tube in side the tv that is what create the picture
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
