Televison & Video Logo
kevin ross Posted on Apr 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a hitachi 51f500a projection tv. my problem is with the red color overlapping. when i go magic focus it stops at the red
  • Anonymous May 22, 2013
    I have a TP55H60 TV that has issues with concergence after 5 - 15 mins. If I adjust convergence in menu or turn off and back on, it is rectified for a short while, but problem comes back.
    *convergence
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Apr 09, 2013
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723394
Points
23750
The convergence has failed you can get the convergence repair kit for that model at the following link . The kit contains the parts and the CD with instructions Its the last one listed on that page. http://tvrepairworld.com/convergence_repair_kits/hitachi_convergence_kits
5 Related Answers
geemarie
Gayle Ashbach
  • 876 Answers
  • Posted on Aug 07, 2008
SOURCE: Hitachi 51G500 big screen rear projection tv
Is this a new television? Under warranty? You need a service call.
Anonymous
  • 4 Answers
  • Posted on Dec 30, 2008
SOURCE: color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Anonymous
  • 14553 Answers
  • Posted on Oct 30, 2009
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
Anonymous
  • 14553 Answers
  • Posted on Dec 12, 2009
SOURCE: magic focus error Hitachi 51F500A
ok, you have more than 1 post for this set--this model uses two of the STK-392-110 OR 392-150 Convergence chips.
If magic focus will not adjust the picture both chips need to be replaced--about 13 dollars in parts if purchased on Ebay.
Green is not offered to be adjusted since it determines the geometry of the picture--red and blue are adjusted to it.
Let me know how much skill you have and I can tell you how to fix the set--it requires two things--getting at the chips and being able to unsolder and replace them--there may or may not also be some resistors around them that are now bad and need to be replaced.
most shops get 300 or more for this repair--total parts cost if you are able to do it yourself is under 30 dollars.
If this helped you rate this solution as I do this here for free.
SD TECH
Anonymous
  • 321 Answers
  • Posted on Mar 22, 2010
SOURCE: Have Hitachi 50 inch Projector TV, model 51F500A.
that is come from your convergence panel theres
2 ic call stk - xxxx
youe have to replace it and then remake alignement for your convergence you should have it in the menu adjustement then magic focus will finalized and you can replace the 45 volt regulator transistor
hope that give you a idea//and should not be to expensive if you get an honest
good luck
Testimonial: "Thank you! Gives me a good starting point"
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
2answers
Colors are out of focus and magic focus wont fix
If you have tried the customer convergence menu/control and can not set the convergence you have a fault with the electronic circuit that controls the convergence of your 3 picture tubes this overlaps the 3 colors red, green, blue to create the proper color combination's of colors for a proper picture
1helpful
Have Hitachi 50 inch Projector TV, model 51F500A. Built 6/2004. Picture has shadows, primarily in red color, on objects or writing. Top 6 inches distorted as well as bottom 2 inches. Tried Magic Focus...
good luck
ATTN SD Tech :Hitachi 51f500a cant make out resistor value
Do not guess on Hitachi resistors...every model is different. Go back to the company you bought the parts from and ask them. If you did not buy instructions goto tvrepairkits.com - they will help you out.
3helpful
2answers
Magic focus error Hitachi 51F500A
SD TECH
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
1helpful
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Hitachi Mode; 53UDX10B
http://serviceman.site88.net/index.htm
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
