Microwave Ovens Logo
Kris Henneman Posted on Jun 30, 2017
Why Must I Add 1 Minute to Everything I Heat?
The microwave stopped heating anything less than one minute. At the one minute mark, the fan gets quieter, and the microwave seems to increase its power because the light inside gets dimmer, then it begins to heat. So now, no matter what we heat, we must add 1 minute to the time. As an example, yesterday I was trying to soften some icing for on cinnamon buns, which is normally done in 8 seconds. I had to heat it for 1 minute and 8 seconds.
  • Kris Henneman Apr 23, 2013
    For anyone else out there that may have this same problem, I have discovered the solution. Apparently this microwave heats at a higher level for the first minute, and there is a fuse that handles this. I had a repairman come out to fix it and so this fuse ended up costing me $100. We actually had to take the microwave off the wall, then take about 30 screws out to take the cover off the microwave. Then on the right side behind the control panel wall is the 20A fuse which was fried. Do not confuse this fuse with the one that is directly behind the control panel which is accessible without taking the unit off the wall. This one isn't that easy to get too. The repairman replaced this fuse and the microwave starting heating during that first minute again, so all is well now. I hope this helps someone else before they have to spend $100 for a fuse.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 11, 2007
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Anonymous
  • 619 Answers
  • Posted on Apr 16, 2008
SOURCE: Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 18, 2008
SOURCE: oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 10, 2009
SOURCE: Microwave stopped heating, evenything else works
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Feb 10, 2009
SOURCE: F2 code on display - microwave does not heat
F2 on this model means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is available already mounted on a new control panel frame. It runs a little more, but saves a lot of time consuming and aggravating work.
In this case, you simply move your circuit board into the new frame.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove a few more screws and disconnect the wires.
It is part # AP3673562 (same as 8205018) and runs $80.97 + shipping here.
1helpful
2009 whirlpool microwave
If the delay in heating is exactly the same each time, you might have some sort of control panel problem. If it is approximately the same each time, you may have an intermittent magnetron that is failing to oscillate until the heater reaches a high enough temperature to emit an adequate number of electrons.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Please I need the wattage of GoldStar microwave Model ER-868 so I can heat a heat pad for a sick animal
Wattage really doesn't matter much for what you want to use it for. Start with 2 minutes and test. If it's not hot enough add 1 more minute
2answers
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Ge adora over the range microwave, runs but does not heat
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
First, use this water method to double-check if there is actually an issue with your microwave not heating:
1. Fill a glass measuring cup with water to the 1-cup mark.
2. Set the microwave to heat on full power for 1 minute.
3. Repeat the process with fresh water a handful of times.
4. If the water is not consistently warm, your problem is confirmed.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
If the microwave senses an open door, it will not run. Check to see if a defective or loose door-safety interlock switch is to blame. If tightening it doesn't work, a replacement may be necessary.
Did you know? Neglecting to hit the STOP/CANCEL button on the microwave before you open the door to remove your food damages the safety switch over time.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
There may be an issue with the circuit board and its connections, and that work is best left to a qualified professional.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
Adds extra minute
always put in one less minute and if it adds you'll be right but if not just send it back through for another minute
4helpful
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Microwave lights and buttons work but doesn't heat up anything
When you start the microwave say for 1 minute. Listen closely when you hit start, the light should come on and about a 1/2 second later you should hear a little click and a slight hum. This means the controller is turning on the high voltage transformer and that part of it is working. My guess is that the magnatron is bad. That's the most common problems with all brands of microwaves. The mat on the top should not have caused the problem since the microwave has heat shutdowns in it. I would say that it's a 90% chance it's the magnatron. Most microwaves have a 5 year warranty on that part. Look at your owners manual. Good luck.
Scott
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
