SOURCE: charging ipod 4gb
Yes, the iPod will show that it is charging on its screen. Disconnecting without ejecting can cause data loss of whatever is stored on the iPod
Ejecting is when you remove the iPod from the desktop by dragging its icon to the trash or clicking on the down arrow next to the iPods name from within iTunes.
If you use the library computer, usually a Windows based OS, you'll need to click on the iPod icon from the task tray on the lower right of the screen. You can right click to select the remove option
SOURCE: 16 gig ipod nano screen has frozen screen
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
SOURCE: How do I eject my nano ipod before I disconnect from the computer
on your itunes there should be a picture of the nano on the left side bar of itunes with a little button beside it... click on this button to perform the eject feature
SOURCE: my iPod screen says Connected eject before
my ipod nano model a1285 is said eject before disconnecting what can i do?
SOURCE: my ipod is says eject before disconnecting
i have an ipod classic it used to do that now i can just disconnect without ejecting since it has received several software updates previous to that if i unplugged the ipod before ejecting the ipod froze online i learned how to reboot the ipod if it froze
Testimonial: "thanks"
