Question about Whirlpool 24" Double Electric Built-In Wall Oven
Need manual for model 6AKZ167/1X/01 made in Italy
Two built in ovens in one piece, in rental unit with no manual provided, apparently missing. Unit made in Italy, maybe 6 years old.
4 Suggested Answers
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Posted on Feb 24, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: The inside glass of my built in double electric
You should be able to obtain a replacement door glass from the manufacturer. They are normally available for most makes of ovens.
Posted on Jan 26, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: I have a Whirpool AKZ451/IX/01
Hi.
There had been a short.I think the only replaceable fuse is the one built in with the power cord. This kind of oven usually do not have replaceable fuse in control board.
If the range top ignitor is not working, check the power cord first. If it is fused replace the fuse. If that does not help the power cord should be tested to check if it is broken. Test is done using a multimeter to make sure that the power cord circuit is not open or shorted..
The point where the short usually occurs when you replace the element is the fan wiring. Check fan wiring harness and the fan motor itself. If the appliance is tripping the circuit breaker the oven can be tested for few seconds with fan not connected. If it does not trip, then the fan is shorting.
If oven is tripping check also element's wiring.
If the oven is working (turning on) but there is no heath read temperature probe impedance, double check elements and wiring. The problem can be the temperature sensor located inside the cavity.
Regards.
Ginko
Posted on Aug 23, 2011
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 | Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Bosch oven HBN 1312.0
Please double check the model number on the unit. On the Bosch site, I found a number of models with that started HBN1312* . However the model number had another digit after the 2 and the zero was followed by a letter and a slash before additional numbers.
The model HBN131220B/01 is an all electric oven. The external dimensions for the wall oven are 595mmx595mmx515mm. I'm not sure about the internal capacity for the unit. Some documentation (including the user's manual) are available from the Bosch support site: http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM . Enter HBN1312 in the search box to find the documents.
I hope this helps.
Nov 24, 2013 | Ovens
I moved into a new flat and the AKP 239/01 IX stove was already built in and there is only user manuals in every other language except English!! The owner does not have it and no-one knows where it is! I...
google -- user manual for ( make and model of stove ) and download the pdf version
failing that go to places like Jaycar and buy an infrared thermometer
you aim this unit at where you want to read the temperature and it reads it
so aim it at the oven glass and you have the temp
or aim it at a hot plate and you have the temp
Sep 08, 2017 | Whirlpool Ovens
How do I troubleshoot my Magic Chef electric built
Hi,look in the control console for the tech sheet or under the top of the unit.A good place to start.Hope this helped.
Nov 17, 2009 | Ovens
Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Jul 10, 2009 | Gaggenau Ovens
Shouldn't all models come with a manual,well we did not get one. Where do we obtain a manual from if you don't get joy on the website
Hi! You are right, every product should have a manual with it and normally every manufacturer is providing the user manual. However, the model you have got might have not provided the manual inadvertently. Please tell me the make and model number of your Unit so that i can provide you with model specific information. Thanks Rylee
Jun 06, 2009 | Ovens
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 24" Double Electric Built-In Wall Oven Logo
173 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
