Samsung ML 2010 - prints out of margin. Is this the electrical board failing? It works fine sometimes, others it only prints 3/4th of hat it should, out of margin.
I have the same problem. Now it wont print at all. A msg came out saying some errors happen. doesnt mention whatkind of problem.I have the same problem. Now it wont print at all. A msg came out saying some errors happen. doesnt mention whatkind of problem.
try taking off the rear cover and holding down the plastic switch near
the top of the circuit board. I have marked the location in the image
below. When i was having trouble with this printer i just held it down
towards the ground for around 10 seconds and it printed a test page just
fine.
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
u cant install a printer without any drivers u need them to send the spooler and other functions to the printer so it can work fine without any problems
go here and download the latest drivers install them than follow the driver instructions
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
First open all covers and make sure there is not another piece of paper stuck in the machine. Check under the toner cartridge. If you are sure there is no other paper stuck, try unplugging the machine wait about a minute and plug back in.
The Report sent to printer should be in a recognised fonts and formats. If It work on other applications like word excel then you need to solve this through ur programmer of Visual foxpro reports.
please install supported driver
