Scosche Industries Scosche Slc4 Speaker High Level Converter Logo
A
Anonymous Posted on Apr 07, 2013
Slc4 wiring diagram - Scosche Industries Scosche Slc4 Speaker High Level Converter
Scosche Frosted Clear & Black Audio Cable
What is the problem with it? Need more details please.
6helpful
Need a wiring diagram for the FAI-3A
you can download the instruction manual for free at the following link.
http://www.scosche.com/car-audio/product/999
Schoche converter trouble
yes , if you do not make your connections right you could probably damage the high to low, verify that all the wires you tapped into where speaker wires
2helpful
Scosche FIA-3A Tie into rear spekers of a 300C to power a sub amp
Hello herg1076,
Here's a link to www.modifiedlife.com which will have a page showing the color codes for your vehicle wiring. The 2008 Chrysler 300 rear speakers are shown as follows: Left positive is Dark Green/Tan, Left negative is Dark Green/Gray, Right positive is Dark Green/Brown, and Right negative is Yellow/Green. Other models and other years will be different, so be sure that you browse to the correct color codes for your specific vehicle.
Hope this helps.
1helpful
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
1helpful
Need wiring instructions for vbx12a
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
10helpful
Need wiring guide
<img src="http://i44.tinypic.com/2nbaf0i.jpg"><br><br>I think THIS is what most people have been looking for.
3helpful
2answers
Wiring diagram
For Scosche FA1-3A (adds RCA outputs to factory radio w/no RCA outputs)
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
