The default code is either 0000 or 00000. That is, four or five zeroes. You can set a new pairing pass code once you connect it to your phone by changing the pairing code from under the connected devices settings in your bluetooth menu.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Headsets, car kits, and such, have a hardcoded passkey, usually set to '0000' (four zeros).
On the other hand, for pairing between smartphones, computers, and such, the device which starts the pairing process can choose any code the user wants. You could use e.g. the same '0000' from the hardcoded devices, of course, provided that the device you are pairing yours to, specifies the same pairing code.
Hope I have made myself somewhat clear here, since English is not my natural language.
Cheers!
Carlos
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
I can't pair my h300 and my ev it keeps saying no device found. Help!!!??
