My Vacuum cleaner model Sanyo Marathon Cyclone SC-XW33G with Motor model number SCM-AR150C has its carbon brushes worn out. I'm looking for new carbon brushes for it. Any idea where I could find these carbon brushes?
SOURCE: fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
SOURCE: I have been given a
Two solutions come to mind---1) Find a local vac store, NOT a department or big box store, and bring the bag to them.Sometimes on the bag is an identifying letter or number and on many you need to remove the bag to see it. Also bring your make/model info.Many manufacturer bags are for identical machines that have been labeled for a retail chain.Panasonic product with a Kenmore label for instance.
2) Ebay has some of the best deals and widest array of harder to find bags,filters and accessories.Good Luck-Scott
SOURCE: Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
SOURCE: Motor Brush for older model Filter Queen
Is there a Johnstone Supply in your area? How about an ACE Hardware. A vacum repair place? Sewing machine repair place?
If you have the data, ACE or Johnstone should be able to help you. Don't discount other electrical supply places. You will not get help at a big box place.
When I Googled "Filter Queen parts", I found lots of places on the WWW. There must be something close to you.
Give it a try. Let me know if this works for you.
a
change carbon brushes
