Computers & Internet Logo
Posted on Apr 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on compaq presario cq57 screen says system disabled
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Apr 08, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015116
Points
21773
You get nothing at boot? No BIOS screen? Try this, remove all media, DVD, CD, USB, etc., unplug, remove battery, plug in, reboot. OR try to boot to safe mode. Post results.
5 Related Answers
puertobori
  • 7733 Answers
  • Posted on Sep 30, 2011
SOURCE: Compaq presario CQ57 screen is black even when the
You need to test your video card.
antiochpc
Kevin Shafer
  • 1314 Answers
  • Posted on Jun 22, 2008
SOURCE: reformatting my compaq presario using my recovery disks
To turn on system restore, go into control panel, system. Click on the system restore tab. There you can turn on your system restore again.
Anonymous
  • Posted on Apr 05, 2009
SOURCE: disable sata in bios of compaq CQ40 laptops
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
contratek
contratek
  • 83 Answers
  • Posted on Oct 14, 2009
SOURCE: Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Anonymous
  • 32281 Answers
  • Posted on Feb 24, 2012
SOURCE: compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Error message System Disabled code 70876817 on Compaq Presario CQ57. What do I do?
older Compaq day, wow.
the C57 has many numbers in suffix, 57 is not just one PC. ok.
why not read the service tag first and tell the full model number first. 2011 year , is not too old just 2 years before all compaqs ended, for ever.
or google that code.
here I will for you., and zip nada
so you did not tell the story, you push the power button
with main battery removed, (big bat out ,yah they SHORT)
and push power for 10 seconds and release power.
1: fan silent, it must not be, this is first.
2: screen dead, no 70876817, POST code text?
3: bios hot keys dead.
4: Bios screens dead.?
5: windows login screen missing? if it is even windows at all?
no beeps
no flashing LED codes? repeating endless.
2answers
How do I turn off internal microphone on compaq presario CQ57
Go to operating system Sound configuration module. Turn off mic.
Half my screen doesnt work on my compaq presario. How can I do a factory restore if I cant see the screen and what option to click
I would definitely not try to do a factory restore without a full screen showing. Are you saying that the external monitor does not work for system restore?
amazon seems to have replacement LCD screens for $51.93
http://www.amazon.com/COMPAQ-PRESARIO-CQ57-229WM-SUBSTITUTE-REPLACEMENT/dp/B005IUFKKW
Factory reset cq57
click run on your desktop, type restore exe, or recover exe there is also msconfig whitch you only adjust what you know and messing with this folder helps many times but should you disable part of the operation system and you don`t have an operating system any more and need to reload a new one.
Compaq presario cq57 my screen turns purple
Hello there!
It could be one of these:
1) bad monitor video pixels array.
2) Bad Video Card (heating)
clean your fan, for heating!
How do i toggle the mouse pointer on my compaq presario cq57?
Usually on the Presario models there is a very small button just about the mouse trackpad that will disable and enable the use of it. It's usually between the trackpad and the keyboard
How do I disable the wireless key on Compaq Presario CQ57 keyboard ?
We have several terminals with keyboards that are used by different people during the course of the day. We had a similar problem with the Caps Lock and Num Lock keys. Solution(s): Straighten out a paper clip and make a quarter inch hook at one end. Insert the hook under the offending key(s) and pop it up. You can easily replace the key should there ever be a need. No ham, no foul.
5helpful
2answers
How to replace cq57-229wm screen
HI,
On amazon you can purchase display for affordable price
Amazon com cq57 229wm screen. Take a look, but be awero... read reviews first.
regards
Mark
Grand Canyon Tech
Grand Canyon Tech
