SOURCE: Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
You might want to check with your provider to make sure that they haven't changed anything. Power cycle the modem, and even perform a hard reset if possible, usually by means of a small button on the back of the box.
Of course you could have just got a bad modem, and in that case, it's just as easy to take it back where you bought it.
