After defrosting manually, works for 3-4weeks
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold
air around in the freezer and blow the cold air from the freezer into
the fresh food section, it also sucks the warm air from the fresh food
section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
SOURCE: GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
