I need hp photo smart c4385 software for my hp laptop computer window 8 bit
Dear Victor,
For downloading driver software, please visit the HP
site page : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3651156.
On this page, please select your OS and click next. Now, there will be
option called "Driver - Product installation software" section, expand
and select appropriate version you need to install and you will be taken
to download page. Before installing, just remove previous software, if
installed (recommended).
SOURCE: cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
SOURCE: When installing a drive for HP Photosmart 7250 get Fatal Error
it may not be due to the windows installer, all drivers for vista 64 bit must be approved and signed by microsoft or they will not install, this is not true for windows vista 32 bit however.
SOURCE: wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
SOURCE: Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
SOURCE: Unable to print on wireless network or send e-mail
Recheck that the printer is shared by the computer it is connected to and that all PCs are on the same network. If no success try disabling the firewall on the pc that your printer is connected to. (If printing now works readjust the firewall permissions).
On the second open Internet Explorer; Tools; Internet Options; Connections and make sure that there is a selection for... Never dial a connection.
