Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
SOURCE: Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor. This is where the cool air comes out into the fridge section. On this model it is a fairly common problem and comes a whole assembly. The part # is WR49X10091 and will cost anywhere from $100 to $122. Knowing this model I would bet this is your problem. If the damper is bad and stuck open cold air will just keep blowing in. It is suppose to open and close based on the temp setting. Let me know if you have any other questions.
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
SOURCE: Maytag side by side refrigerator - freezer side
you probably have a defrost problem. what you would see is frost on the rear panel of the freezer section at the back bottom.
this is common and you most likely need to replace the adaptive defrost control.
it is located inside the refr control box. you have to remove the cover and then the air housing with the lights attatched to it. once you have this housing down, then the "adc" is on the right rear and looks like a computer board.
dont try to figure out how it works, just replace it and then let the freezer warm up to remove the frost from the freezer coils. have a towel ready to pick up the excess water that will drip off the coil and onto the floor.it will take about 6 hours or so of being shut off.
after it has defrosted then turn the unit back on and with the new board it will start cooling properly again.
SOURCE: The refrigerator door side does not shut tightly.
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
For this problem, its indicating towards
problem with damper assembly.----------
The working procedure of this unit is as
follows: --- The compressor starts then it cools the freezer section. When the
freezer reaches its cooling level the defrost cycle starts functioning. In this
cycle the fan in the freezer section starts running and the cool air in the
freezer section is passed to the fridge section and the fridge
section gets cold. The air from freezer to refrigerator passes from the
section, in that section the damper is located. ----------- The damper is
operated by a motor.Its a complete damper assembly with motor included in
it.--The damper has door.Which closes and open with the help of motor.In your
case the damper door is remained open, its not closing.Due to this the cool air
from freezer section is running in to fridge section non-stop.Due to this the
vegetables and other food in the bottom drawer freezing.--------- In this
problem the damper assembly needs to be replaced.---------------
You can get
required parts from online sites like: --- www.repairclinic.com
or from searspartsdirect online site. ----------- This should help.
Thanks.Helpmech.
