SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
SOURCE: Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
